Upload Files with REST API
  • July 9, 2024
  • 337 views
pflegpet
Forum|alt.badge.img+8
is it possible to upload a file to the FME Flow shared resource folder through the Flow REST API? I tried to setup a POST request for https://fme.oebb.at/fmerest/v3/resources/connections/<resource>/filesys/<path> but get a 415 Unsupported Media Type Response. I used the following parameters in Postman:
In this example I want to upload the text file “test.txt” to the shared resource folder “Test”.
Is there a problem with the request, or is this the wrong approach for uploading a file via the REST API? The goal would be to provide a means for external applications to upload files that are then processed by FME Flow. Thank you for your help!
Best answer by lifalin2016
Changing things on FME Server/Flow typically requires authorization, and therefore authentication.
Have you created a suitable token to accompany the request, or a basic digest authentication ?
Otherwise you most likely will be rejected.
Another issue is your <resource> and <path> in your url. These should be replaced by the values FME_SHAREDRESOURCE_DATA and your path respectively in the url, not given as query parameters.
Hope this helps.
lifalin2016
Forum|alt.badge.img+40
  • July 12, 2024
Hope this helps.
pflegpet
  • July 12, 2024
Hi @lifalin2016, accidentally I double posted this question. The orginal post was
Anyway, what you suggested is correct: I had to change the request URL as you suggested and the body in Postman to “form-data”.
Nonetheless, thank you for your help!
