Upload Files with Flow REST API
  • Jul 9, 2024 3:12 PM UTC
  • 446 views
pflegpet
Forum|alt.badge.img+8
is it possible to upload a file to the FME Flow shared resource folder through the Flow REST API? I tried to setup a POST request for fmerest/v3/resources/connections/<resource>/filesys/<path> but get a 415 Unsupported Media Type Response. I used the following parameters in Postman:
In this example I want to upload the text file “test.txt” to the shared resource folder “Test”.
Is there a problem with the request, or is this the wrong approach for uploading a file via the REST API? The goal would be to provide a means for external applications to upload files that are then processed by FME Flow. Thank you for your help!
Best answer by hkingsbury
The below screenshot is working for me:
Using basic auth under the Authorization tab
hkingsbury
Forum|alt.badge.img+73
  • Jul 9, 2024 11:36 PM UTC
pflegpet
  • Jul 10, 2024 8:07 AM UTC
Hi @hkingsbury, after changing the URL and body the request is working for me as well. Thank you!
johannafalk1
Forum|alt.badge.img+20
Hi ​@hkingsbury,
I have a similar problem. When I follow the steps above, I get the "message": "Error communicating with FME Flow host XXX \nContact your FME Flow administrator who can investigate the log files for further details.\nAlso see: http://fme.ly/e100007#error-communicating-with-fme-server-hostConnection refused: connect"
Unfortunately, the link provided there, doesn’t seem to exist anymore.
Just for testing, I also tried to upload through the api v4 - using this POST request:
fmeapiv4/resources/connections/{connection}/upload?overwrite=false&path=%2FTest%2F
Then I get this "message": "The required parameter \"files\" was not found in the request."
Could you help me?
Best regards,
Johanna
