Survey123 not triggering webhook but Postman does
  • Aug 29, 2024 12:44 AM UTC
  • 306 views
bromp
Forum|alt.badge.img+9
Hi there,
I have set up a webhook in Flow that is (supposed to be) triggered by a survey123 submission. I have added the webhook in survey123, saved and updated the survey on my device. I have saved and started the automation in Flow. When i submit a survey there are no event counts running through the automation and there are no logs. I have tried both with https authentication and without and have tried with another very simple survey.
When https authentication is off, I can test the webhook via postman which successfully triggers the automation.
This could be more of an esri question but is there anything I am missing from this webhook set up?
I have other webhooks connecting power automate to my surveys and they work fine.
Cheers
TandraAtSafe
Forum|alt.badge.img+8
Hi @bromp
I believe in order to have Survey123 trigger the webhook you need to have your FME Flow publicly accessible, or at least have anyone submitting the survey must be on the same network as the FME Flow server and have FME Flow configured for HTTPS/SSL. I hope this helps, please let me know if I misunderstood your question.
It sounds like you’ve already got the hang of webhooks and Survey123 but you might be able to find more information in our tutorial: Push Data from ArcGIS Survey123 to an Application in Real-time with Webhooks
