Subscription Error: Unexpected value "\\\\path\\*.csv" for parameter "value," expected list
  • Jan 23, 2019 10:41 PM UTC
  • 106 views
amc
Forum|alt.badge.img+3
I have a schedule that runs fine using a wildcard to find the source files.
Rather than running the workspace every 10 minutes I would like to set up a directory watch (or similar) to trigger the workspace to run.
When creating the subscription I get this error: Unexpected value "$(a)/ServiceOrders/FME/NotificationDefectsExport*.csv" for parameter "value," expected list
The issue appears to be using a wildcard in the source file of a subscription.
I have tried with both UNC source path and by setting up a resource in FME Server.
Permissions are not an issue as the workspace runs fine on a schedule.
Hi @amc,
Are you able to share a screenshot of how your schedule is set up, showing the workspace parameters specified there?
What is the $(a) referring to?
With the directory watch publication, do you want that to run and read in all csvs in that location, or just process the one csv at a time that is added to the directory?
amc
  • Jan 28, 2019 7:49 PM UTC
Hi @jlutherthomas
This is the schedule set up:
If I try adding the same parameter to a subscription I get the ‘unexpected value’ error.
That is when I set up set up a resource to see if that made a difference, that is the $a you see on the subscription.
I would expect the directory watch to process one csv at a time, but only csv’s matching the naming convention ‘NotificationDefectsExport*.csv’. There will be other csv’s in the same location that I do not want this workspace to process.
amc
  • Feb 20, 2019 1:49 AM UTC
There was something wrong with the subscription. I deleted the subscription, created a new subscription (exactly the same) and now it validates.
