Subscription Error: Unexpected value "\\\\networkpath\\" for parameter "value," expected list
  • Oct 28, 2016 12:46 AM UTC
  • 105 views
I have a publication that monitors a folder for new files that are created.
I also have a working workspace that takes any number of files from a network location and uploads them where I they need to go.
When trying to set up a subscription I get the following error
I have been able to run the workspace on its own however it fails when initiated by the topic.
I can see the SourceDataset_PATH parameter is missing from the log but.
Published Parameters
Parameter Value SourceDataset_PATH FME_TOPIC_MESSAGE$(FME_SHAREDRESOURCE_SYSTEM)temp/subscriptions/277a9c3190634de39102c05756666082.json FME_TOPICDatasetWatchstatusMessageParameter 'SourceDataset_PATH' must be given a value.
Any ideas?
itay
Forum|alt.badge.img+19
  • Oct 28, 2016 5:02 AM UTC
is there a filter specified in the path and directory reader?
There is only an asterisk(*) in the path filter, so I assume it is looking at all.
itay
  • Oct 31, 2016 7:26 AM UTC
In that case it probably not finding any datasets/files to return, hence the error....
itay
  • Oct 31, 2016 9:13 AM UTC
Could be a case of access rights to the location, can you access the location from the machine where FME Server is installed?
