Stream a HTML writer from Automation App
  • May 6, 2024 11:36 AM UTC
  • 216 views
worjak
Forum|alt.badge.img+4
I’m trying to make an Automation App that ends with a workspace that streams a html writer. The workspace will stream the html writer if I make it a Workspace App so the worspace works as intendet.
When I put the workspace in the end of the automation and make this a Automation App the workspace is executede and writes its html but the html is not returned/streamed to the user in the web browser!?
What to do?
Best answer by sanaeatsafe
Hi Jakob! At this time, Automation Apps do not support the transformation services (Data Streaming, Data Download, etc.). I recommend using a Workspace app, instead. If the app workflow requires multiple workspaces to run, you could consider using a REST API request or JobSubmitter transformer within the workspace as a workaround, but the behaviour won’t be exactly the same.
If Data Streaming is something you’d like to see in Automation Apps, please vote for the idea on the community:
sanaeatsafe
Forum|alt.badge.img+9
  • May 9, 2024 3:54 PM UTC
danilo_fme
Forum|alt.badge.img+58
  • May 10, 2024 7:44 PM UTC
nice @sanaeatsafe
worjak
  • May 17, 2024 12:40 PM UTC
Thanks! I took the Automation and REST API out of the equation and used the FMEFLOWjobsubmitter (and fmeflowjobwaiter) to execute the workspace inside the merge-split-block. Thus returning the respons to the user via the html-writer.
