SMTP error
  • Jun 2, 2017 11:43 AM UTC
  • 10 replies
  • 106 views
itay
Forum|alt.badge.img+19
Hello all,
I am getting an error message stating that the email sent via the Emailer transformer does not contain a header (From).
Here is a description of the error:
SMTP error from remote mail server after end of data:
550-5.7.1 [2a00:4e40:1:1::9:4 11] Our system has detected that this message
550-5.7.1 is not RFC 5322 compliant:
550-5.7.1 'From' header is missing.
550-5.7.1 To reduce the amount of spam sent to Gmail, this message has been
550-5.7.1 blocked. Please visit
550-5.7.1 https://support.google.com/mail/?p=RfcMessageNonCompliant
550 5.7.1 and review RFC 5322 specifications for more information. o16si20691209edc.165 - gsmtp
I am actually specifying a From in the emailer but it seems not to come through:
Does anybody know if its a known issue? I am using FME 2017.0.0.0 (20170228 - Build 17259 - WIN64)
Thanks in advance.
Best answer by takashi
Hi @itay, this seems to be a known bug that the "From" header will be missing when you send an Email from a generic SMTP to a Gmail address or to an address belonging to the same domain as the sender's address. The Gmail server will reject an Email without "From" header and return the error you've observed. I've reported the bug to Safe already and heard that it is addressed to be fixed in FME 2017.1.
  • Jun 2, 2017 11:50 AM UTC
Why is the "To" attribute name red? Have you tried fixing that first? Same thing for the attachment filename.
itay
  • Jun 2, 2017 11:54 AM UTC
The transformer is not connected.....its more for displaying the settings, once connected the attachment is send.
  • Jun 2, 2017 12:02 PM UTC
Ok, thanks, makes sense. Could it be that gmail doesn't like that your From-address doesn't belong to gmail?
itay
  • Jun 2, 2017 12:37 PM UTC
Dont think so because sending it via the mail is successful.
  • Jun 2, 2017 1:03 PM UTC
You could use something like Fiddler to check what FME is actually sending.
itay
  • Jun 2, 2017 1:14 PM UTC
Since I am sending the mail via the provider I think that it wont be possible for me to use it
Mind you I have requested support from the same provider on the subject, was just wondering if other community user have encountered such an error before.
  • Jun 2, 2017 1:15 PM UTC
itay
  • Jun 2, 2017 1:20 PM UTC
Hi @takashi, thank you for informing me.
  • Jun 8, 2017 6:25 AM UTC
Hi @itay, I was informed that the relevant issue has been fixed in the latest FME 2017.1 Beta build 17503, and confirmed the upgraded Emailer works fine :-)
itay
  • Jun 8, 2017 7:12 AM UTC
Hi @takashi, excellent thank you for sharing.
