setAttribute Python Caller
  • October 22, 2021
  • 1001 views
mr_fme
Forum|alt.badge.img+9
I have a script that does an area calculation using arcpy, the two calculated areas are output in the log, I need each one of them to be output as an attribute, how to do this? I'm new to python at FME.
log:
imageThe output, it doesn't help me at all.
Thank you for your help
Best answer by david_r
Any particular reason for using arcpy rather than the AreaCalculator transformer?
Other than that, you can add the following on line 124:
feature.setAttribute('total_xyz', total_xyz)
feature.setAttribute('total_TAL', total_TAL)
I've substituted the red "blob" for xyz above. You'll need to also expose the new attributes in the PythonCaller settings.
  • October 25, 2021
mr_fme
  • October 25, 2021
Hi @david_r​
Helped a lot. Thank´s
This script is huge, I don't want to change its structure but, I would prefer to use the Area Calculator.
Thank´s
