Set an automation to trigger when a SharePoint folder is updated
  • Dec 15, 2022 9:06 PM UTC
  • 652 views
erivero
Participant
I have a workspace that needs to run when there is a new file in a SharePoint folder. Is it possible to set up an automation that would work similar to Network or Resource Directory?
matt.m-at-safe
Forum|alt.badge.img+14
Hi @erivero​, there is no Automation trigger for a SharePoint Document Library watch.
You could potentially create a SharePoint Webhook and then use the Webhook Trigger.
Here is Microsoft's documentation on SharePoint Webhooks.
And here is a blog about getting started with Webhooks.
Another option is a polling workflow. This uses a schedule trigger to regularly run a workspace and connect to SharePoint to see if documents have been added. This will not be as immediate as a webhook, but potentially easier to implement. The SharePoint List Reader can read Document Library data, like the created or modified date of files. You could then use a ChangeDetector to determine which records have been added to the list or changed.
See Introduction to Scheduling and Change Detection Workflows in FME Server
