Reuse my OSM to .GBD template
  • April 5, 2024
  • 88 views
peterverst
Hello,
I am using FME (ESRI version) and I built a project that reads fileXX.osm.pbf. I use a clipper and schema adjustment and write this to a .gdb (ESRI). In my project, I do this for a part in Norway. All is great so far.
Now I want to use the same project but with a different osm.pbf file, a different clip file, and a different .gdb. I see that the project is reading, but when writing, I get a message that it did not work because names are different. I tried to save a template and start a new project from the template, but it's the same result.
I hope someone can point out what I am doing wrong here.
Greetings, Peter
nielsgerrits
Forum|alt.badge.img+64
I have no idea what kind of message you got. Can you printscreen it?
peterverst
  • April 5, 2024
this is the message. So I have a project with data from Norway and this works great but now I want to proces Finland so when I run I adjust to this.
