retrieve last used oid value and set counter to start with next number. Postgres 14/PostGIS oid
  • Jul 31, 2023 3:21 PM UTC
  • 109 views
gisbradokla
Forum|alt.badge.img+27
I am writing to postgres/postgis st_geometry in an autmation that is loading many dwg datasets. (runs workbench on each dwg)
The postgis writer shows that ver 14 ignores writing od.
I need to get an oid calculated beginning with the last oid used (in the previous automation)
NOTE: postgis writer specifies that oid is ignored at postgres 14.
I tried just using a counter and hoped that writing to existing would automatically write the oid. (I get an error the oid already exists).
I am using this oid as the primary key so that It doesn't have to be set when adding to esri.
I have attempted to read the flat postgres table and sample the last n and then use that as a parameter to set the start number of the counter. But have not been successful getting that to work.
imageAny ideas on how to do this?
itsmatt
Forum|alt.badge.img+48
  • Aug 1, 2023 1:28 PM UTC
well, if your oid's are always sequential (that is the highest number is the most recent) then you can use this call inside an SQLExcecutor to get the last row.
SELECT * FROM "<table_name>"
ORDER BY "oid" DESC
LIMIT 1;
This should give you the last record from the table. From there you can use a counter starting from the oid value (or oid+1 ).
