Retrieve data download url
  • March 5, 2018
  • 221 views
After running a workspace download service I cant find how to get the download url in my custom web application.
Starting the workspace: GET to http://server/fmedatadownload/repo/workspace.fmw
Getting transformation status: GET to http://server/fmerest/v2/transformations/jobs/id/" . $id
But then finally, how do I get the download link to display in my app? It does deliver with email and there it appears just as expected.
lars_de_vries
Forum|alt.badge.img+10
According to the documentation, a URL will be provided in the response elements. You should include this link in your custom web application.
jneujens
  • March 21, 2018
What is the the point doing there when you call '$id'? Seems unnecessary to me?
There are multiple ways to get the 'resultDatasetDownloadUrl' parameter using REST services.
Can you try to use http://server/fmerest/v3/transformations/jobs/id/<id> (use v3 instead of v2)?
That should work fine... Have you checked that the data download package is actually created?
Otherwise, http://server/fmerest/v3/transformations/jobs/id/<id>/result shoud also give you the 'resultDatasetDownloadUrl'.
jneujens
  • March 28, 2018
giskis, is your problem solved?
