rest api - want to create a session token
  • May 26, 2025 1:23 PM UTC
  • 103 views
gkvoelkl
Want to create a Session Token with JavaScript and api. What is the way to do it with rest api v3?
best regards Gerhard
alexbiz
Forum|alt.badge.img+35
  • May 26, 2025 2:25 PM UTC
Hey Gerhard,Β
you can find the Create token endpoint documentation here :
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/#!/tokens/createForm
I can't help you with the javascript part though.
gkvoelkl
  • May 26, 2025 3:07 PM UTC
I want to create Session Token and not api Token. The documentation does not explain, which Token will be created. I need an JavaScript example. In the SafeΒ JavaScript examples they use an older deprecated api. Perhaps there is an fme developer forum.
alexbiz
  • May 26, 2025 3:32 PM UTC
After some testing and digging, I found that the trick to create a session token instead of an API token is to add the s=1 parameter:
http://FMEFLOWURL/fmerest/v3/tokens/?s=1
The rest of the request remains the same.
