React against a cancellation of a workbench job?
  • October 17, 2019
  • 14 replies
  • 65 views
xtian79
I have a long running workbench on the FME server. Is it possible to take actions if a job submitted is canceled?
proposed workflow
1. submit a job
2. cancel a job
3. write into a file information regarding the job that was cancelled (is possible to do it inside the same workbech? is possible to do it with another workbench? a subscription could help??)
[EDIT]:The idea is that step 3 is automatically triggered after the cancellation of the job, that is what I mean by "React".
[EDIT]: I am using FME Server 2018.1.2 - Build 18590 - win64: I notice that JOBSUBMITTER_ASYNC_JOB_FAILURE topic is not triggered when a job is canceled.
thanks for any hint provided.
Best answer by mark2atsafe
I believe this has been implemented in FME2019. See this idea for more info:
https://knowledge.safe.com/idea/76535/topic-on-cancel-1.html
In short, you can use either automations or a traditional topic; but either of those should fire when a job is cancelled, whether it's an automatic or manual cancellation.
I hope this helps. I would have brought this to your attention earlier, but to be honest I didn't realize that idea had been implemented, so apologies for that.
Pre-FME2019 I think the only realistic way is that suggested by @itay - you would need to have a separate workspace (maybe one that runs on a schedule every minute or two) that checks the completed jobs queue for cancelled jobs. Not ideal, which is why I think we implemented this in 2019.
itay
Forum|alt.badge.img+18
  • October 17, 2019
Hi @xtian79,
You can use the FME Server REST API to query the status of the jobs:
GET /transformations/jobs/id/< jobid >/result
For if you have the job ID or:
GET /transformations/jobs/completed
For all jobs.
xtian79
  • October 17, 2019
Hi @xtian79,
For all jobs.
Thanks for your answer, but it is not suitable for me, because i required an automated/programmed solution, that not involves a permanent pooling for the status of one job. i will complete my question.
itay
  • October 17, 2019
No need to pool foe the status if you make it part of the workflow.
Somehow you will need to get the job status to define if it is cancelled.
xtian79
  • October 17, 2019
As far as I understand you, I can verify the status of a job from the same running workbench? is that correct?
itay
  • October 17, 2019
For that you will probably need a master / slave construction, using the FMEServerJobSubmitter calling the slave workspace in the master workspace. The result of the transfomer can be used to query the job status.
itay
  • October 17, 2019
Another option would be to use a default topic to notify after job completionand have a secondary proces querying for the job status. This is a more generic approach.
nic_ran
Forum|alt.badge.img+16
  • October 17, 2019
I think this would be a good enhancement to the FME Server System Event notifications capabilities. It might be worth submitting a request for this enhancement...
nic_ran
  • October 17, 2019
Actually, thinking a bit more about it, this is already possible.
There are default topics which get published to whenever a workspace fails on FME Server (a cancellation is considered a fail). You just need to set up an Automation (FME Server 2019+) or Subscription (FME Server <2019) to listen for the failed workspace topic notification and then process accordingly.
xtian79
  • October 18, 2019
Sounds good, I am going to try
xtian79
  • October 18, 2019
Hi @nic_ran, i was looking the info in the link that you posted, but that is information from 2013, I tried to look for the latest one, but there is no default topics mentioned in the current documentation.
So far, I try to create a subscription to the topic:
acording to https://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/Monitoring_FME_Server_Activity_Using_Notifications.htm#Monitori2
xtian79
  • October 18, 2019
I set up the subscription to the topic mentioned above, and it works perfectly when I test the topic. Funny part: the subscription does not works when i submit a job and it fails, neither when i cancel it. (I am using the FME 2018 and the workspaces in the samples folder)
nic_ran
  • October 21, 2019
Sorry for the old link. Here's the link from 2016 about default topics (and it's still current in 2019):
https://knowledge.safe.com/articles/30539/workspace-notifications-part-2-configuring-the-def-4.html
You'll note that there are different topics which get notified depending on the service you've configured your job to run under, so make sure to use the correct one (either JobSubmitter or DataDownload). If you're not using those services then you can always create your own topic/notification/subscription. This would give you more fine-tuned control as you could do it for a specific workspace.
xtian79
  • October 30, 2019
After an implementation of a long running workspace, and be able to cancel it (I am not so fast),
I notice that JOBSUBMITTER_ASYNC_JOB_FAILURE topic is not triggered.
As seen in the image , the workspace was cancelled one and failed 3 times, and the topic monitoring show me the 3 failures activation but not the one from the one from the cancel action.
What i am missing here? is this really not supported by FME Server?
mark2atsafe
Forum|alt.badge.img+59
  • October 30, 2019
