Python: No module named Platform
  • January 16, 2023
  • 216 views
jkr_wrk
Forum|alt.badge.img+36
When running FME Desktop and set the Scripting to Esri Python 3.6+ or other Esri Python version and adding an PythonCaller or PythonCreator the workbench fails and gives an error.
This bug seems to be related with Windows removing all Icons form the Start Menu.
Reinstalling ArcGIS Pro seems to fix the problem.
Best answer by jkr_wrk
So reinstalling ArcGIS Pro seems to be the solution.
Have to mention:
Using
Microsoft Windows 10
FME 2012.2.6
ArcGIS Pro 2.9.6
More colleagues have this problem. But all had icons removed from the Start Menu related to the Windows Defender bug. So it seems more than just icons are removed by the bug.
jkr_wrk
  • January 16, 2023
Have to mention:
Using
FME 2012.2.6
ArcGIS Pro 2.9.6
danilo_fme
Forum|alt.badge.img+53
  • January 16, 2023
Have to mention:
Using
FME 2012.2.6
ArcGIS Pro 2.9.6
Great solution!
