Provide specific response body to Webhook POST from 3rd party app
mpittinger
Forum|alt.badge.img+4
Hello everyone-
Hoping that someone may be able to help with this question!
Is there a way to provide a specific required JSON Response body (for example:  {“status”:”OPERATION_OK}  ) to a 3rd party application in response to a successful post to an FME Flow Automation with a Webhook trigger?
I feel like I’m missing something obvious here….
Any help would be greatly appreciated!
Mike
hkingsbury
Forum|alt.badge.img+55
  • March 17, 2024
I don’t think you can customise the Automations to that extent (although I haven't used them much so I might be wrong).
What you could do is instead of calling the Automation, call a workbenchs that is setup:
  • As a streaming service, with a textwriter writing the appropriate JSON
  • To call/trigger the automation
It does add an extra link in the chain, but may be the only way to achieve what you’re after….
mpittinger
  • November 22, 2024
Thanks for the feedback!  Not wanting to impose, but could you provide a basic schematic of what the workbench might look like?
siennaatsafe
Forum|alt.badge.img+11
Hi ​@mpittinger
I had to build a similar workflow for ArcGIS online. I’ll attach my workspace here.
This workspace is trigged from a data streaming webhook.  See this article for details as well: https://support.safe.com/hc/en-us/articles/25407519445901-Submitting-a-Job-through-an-FME-Flow-Webhook-URL
Important notes:
  • This workflow needed a different response based on a GET or POST method. You can delete the TestFilter if that’s not needed.
  • I used a Text Writer to send the JSON back to the source. When publishing this workflow, make sure that this writer is registered to the data streaming service when published to Flow.
  • I used the FMEFlowNotifier to send data to an automation.
mpittinger
  • December 10, 2024
Thank you, so much for the feedback and help!  Sincerely appreciated!
