processing bar for calling time-consuming services
  • May 31, 2016 6:30 PM UTC
  • 45 views
HI all, I want to add a processing bar on my application for time-consuming services so users know the process is still running. I am using FMEServer.runDataDownload(this._repository, this._workspaceNames[2], params, this._displayResult)); How to implement this?
rylanatsafe
Forum|alt.badge.img+14
Hi @wgsl2005, you might consider leveraging the FME Server REST API to help you out...
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/transformations/get_get_15
For example, if you are able to retrieve the Job ID when submitted, use the above REST API endpoint in a loop to poll the status returned by the API.
Let us know if you (or anyone else reading this) has implemented this in a different way!
