Output Map to any size, scale and orientation
  • April 18, 2021
  • 156 views
fme-phile
MapFormatter custom transformer was created so that you can create a map at any size, scale and orientation.
Map Sizes:
A0, A1, A2, A3, A4, A5, A6, A7, A8, Junior Legal, Letter, Legal, Tabloid (Ledger), ANSI A, ANSI B, ANSI C, ANSI D and ANSI E.
Map Orientation:
Landscape and Portrait
Manually entering other sizes could be an option in the future.
I have uploaded the 'MapFormatter' transformer onto the FMEHUB for you to review and provide feedback.
MapFormatterTransformerMapFormatterWorkspaceThis has been tested and at this stage, I am confident that everything works as expected, however will do more quality testing.
Below is an example where the transformer was used to create a map with Aspect:
Map
Map Orientation: Landscape
Map Scale: 1:2000
Map Size: A3
Output MapWorkspace
  1. Lidar was used to create the Aspect
  2. ScaleBar custom transformer was used to create the scale bar
  3. Transformers top left created the Aspect
  4. Transformers top right created the text for the map
  5. Transformers bottom left added the north arrow and the legend.
  6. Transformers bottom right added the scale bar
  7. The legend was created using a separate FME Workspace.
ExampleWorkspaceOutput attributes include:
  1. MAPSIZE: map size i.e. A3
  2. XDIMENSIONS: Map size for the East-West Direction i.e. 420
  3. YDIMENSIONS: Map size for the North-South Direction i.e. 297
  4. ORIENTATION: Format (Landscape or Portrait)
  5. MAP SCALE: Scale of the map
  6. SCALE TEXT: Added so that you can add the scale text on the map i.e. 1:2000 @A3
danilo_fme
Forum|alt.badge.img+52
  • September 20, 2021
Wow @australia​ it is amazing. I'll test it!
