New Files in Folder Not Triggering Automation
  • Nov 6, 2025 3:28 PM UTC
  • 177 views
darrylh
Forum|alt.badge.img+4
This is the first time I have tried setting up an Automation in Flow by monitoring for a new file.
I have a simple workspace that is unzipping a zip file and updating a database with it’s contents. It works in Form and when published to Flow and manually run.
I tries following this article bit nothing seems to happen: https://support.safe.com/hc/en-us/articles/25407764152973-Run-a-Workspace-When-Data-Arrives-in-a-Directory
The trigger is set like this:
I have a filter checking for zip files:
And then a Workspace:
In the log file i gives the line:
2025-11-6 15:24:41 | Performing query against PATH dataset `\\MYNETWORK\ICT_GIS\Projects\DAI-XXXX Land Registry Update\Zipped\TEST.zip\'
It should be looking in \\MYNETWORK\ICT_GIS\Projects\DAI-XXXX Land Registry Update\Zipped\ for a file called *.zip, but the \ at the end makes it look like that is a folder name (maybe I am just misreading that).
Further down it then has a warning:
Path Reader: No files found in folder 'D:\FME Temp\fmeengines\localhost_Engine2\TempFS_1762442681795_3104\dsR_1_0\TEST.zip_0' using glob pattern '*.zip' with glob filter 'FILE'. No features will be read.
The _0 is confusing to me there.
Any pointers would be great
Best answer by darrylh
I think I have got this working, it waan’t the filter in tge automation that was causing the problem, it was the file path extractor in my workspace. While this worked in form I couldn’t use the \*zip in the source data to only fine zip files, so removed that and it appears to work.
So I can put the autionation filter back in just to ensure it doesn’t grab anything
aaron-at-safe
Forum|alt.badge.img+9
Hi ​@darrylh,
Sorry to hear you’re experiencing this issue! Based on the error you’re receiving, it seems as if you may have a Path Filter applied to your Folder and File Pathnames reader for a “.zip” file. Because of this, I suspect that the workspace is looking for a ZIP file inside of the ZIP file that you are already providing through the Directory Watch trigger. Since your Automation is already set up to filter for a ZIP file, this additional filter on the reader itself is not necessary.
This is just a hunch based on what the log is saying, so if this is not the case, please let me know!
-  Aaron H.
darrylh
  • Nov 11, 2025 10:04 AM UTC
