I’m running into an issue with FME Workbench 2021. When I run the workspace locally, all expected files are generated correctly. The same workspace also works when published to our older FME Server (same version, 2021.0).
However, after publishing it to a new FME Server environment (also 2021.0), some of the output files are missing. No errors are reported in the log, but certain files simply don't get written. The log even says they have created the files.
Nothing has changed in terms of file paths or logic – they still use dynamic paths (e.g., FME_SHAREDRESOURCE_TEMP). The only major change is that we replaced FeatureReader with HTTPCaller to avoid a bug with esri_OID in high availability setups.
I’m running the exakt same job but still I get this issue.
I’ve already:
Verified that the paths are correct
Checked resource locations
Tried republishing and updating the “download data” edit.
Still, the problem remains in the new server setup.
What could be causing this?
