Is there anyway to Delay email from FME Server automation?
  • June 29, 2021
  • 85 views
panda
Forum|alt.badge.img+20
I have FME Server trigger event late at night and it will automatically email with the report right after the workspace has completed. Is there anyway to delay the email to send in early morning instead even though workspace still ran at night?
Thank you!
Best answer by gazza
It might be easier to have the first workspace write the details of the email to a text/xml/json file in a resources directory and have a scheduled automation that runs in the morning to process any files in the directory and send emails.
hkingsbury
Forum|alt.badge.img+67
  • June 29, 2021
What you could do is instead of you automation firing an email, get it to fire a separate workbench which has the logic in it to set a schedule that fires a second workbench which sends the email. The schedule can then be set to run at your required time. After the email is send in the second workbench, there should then be some logic to remove the schedule that was set.
gazza
  • June 29, 2021
  • June 30, 2021
You could send the email to your own inbox and delay what is sent out, in outlook all sent emails can be set to send after a certain time.
panda
  • June 30, 2021
Thank you all for the suggestions!
