I'm looking to make a query which uses the spatial data in the planning brief to search cadastre, duct, duct_route and SL layers. So that I can change each planning layer can become searchable and have an output. We are currently working with MapInfo
I'm looking to make a query which uses the spatial data in the planning brief to search cadastre, duct, duct_route and SL layers. So that I can change each planning layer can become searchable and have an output. We are currently working with MapInfo.
Best answer by david_lyons
Not an expert,
But @phillip_bowman, @jennaatsafe is correct, I'd use tester to flick through your polygons and use spatial filters to search your layers. I've attached something I would use for your data set. I would use multiple spatial filters from one tester so each layer can be viewed at each stage then you can merge at output.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
