In the Excel output Feature Type Properties, set the parameter 'Row Number Attribute' to the attribute that will control the row you want the data written to. Also Set 'Use Attribute Names As Column Positions' as Yes. Then add an AttributeRenamer before the output feature type to rename your existing attributes to the desired column names (ie. A,B,C ... AA,BB,CC etc.).
Instead of the method above, a simpler way might be use the Start Position parameter in the Feature Type Properties to set the start column and row for the table.
thanks for reply ,
but I am still confused .i have succeeded to rename the attribute name to >>A and change excel writer properties as u explained
and write it to specific cell in third row as example but how could I write the data that was inside the column down the specific cell .
do u have sample workspace for writing different columns data into specific cells
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
