how to write an attribute that is written into a textfile into an email.
  • January 20, 2022
  • 65 views
imageThis workbench is run on the server and uses the FME Server email generator. We want it to generate a text which includes
  1. the original total records read from 2 separate tables used as input eg 2913 from table 1 and 7429 from table 2
  2. the total number of records in the output file geodatabase.
We have got it to the point that it automatically fills in the total records from input table 2 but not the other 2 numbers. What could we be doing wrong?
Forum|alt.badge.img+62
You have two FeatureWriters, which one is writing the database you'd want to have those statistics for?
And how do you have your FMEServerEmailGenerator set up?
hkingsbury
Forum|alt.badge.img+67
  • January 20, 2022
you need to pass the output of the ServerEmailGenerator into an FMEServerNotifier. In the notifier, you need to specify a topic to post the string to. On your FME Server you need to setup a topic and subscription to send an email
  • January 26, 2022
The feature writer on the left is writing to the database, the feature writer on the right is for logging purposes. The FMEServerEmailGenerator parameters contain 2 email addresses and have the file geodatabase from the left hand geodatabase as an attachment. We don't (yet) have a FMEServerNotifier or a topic setup in the FME Server.
A further issue is that the output of the lefthand feature writer is writing to an existing filegeodatabase rather than first creating a geodatabase and then writing to it. Is that something that is done within the feature writer or is a separate transformer needed for this?
Ok, I think I got what you mean.
It's probably a good idea to use an Emailer instead of the FMEServerEmailGenerator (because it can email directly, rather than creating a topic).
You'll need to take the Summary output of FeatureWriter_2 and join it on to the feature going into the Emailer, then you'll have access to its attributes so you can construct the email body.
