How to verify if all the workbenches in an automation for a particular run/trigger are successful?
  • Feb 27, 2025 10:02 AM UTC
  • 7 replies
  • 244 views
iamprem
Forum|alt.badge.img+7
Problem Statement:
I need to verify if all the workbenches in an automation for a particular run/trigger are successful. There can be multiple runs/triggers in a day, and the number of triggers per day is unknown.
Things I Have Tried:
When I attempt to retrieve relevant data from the FME Flow PostgreSQL database, I can't find a unique identifier for each run/trigger of an automation.
I can see an event_id in web interface, but unable to find that in the postgres database.
Best answer by ebygomm
I think that’s saying you can’t return statistics about an automation via the web api.
You can make a call to return all jobs triggered by an automation
fmerest/v3/transformations/jobs/completed?limit=-1&offset=-1&sourceID=<AuomationID>&sourceType=Automations
I’ve used it to look at how many jobs are triggered from an automation
Forum|alt.badge.img+54
  • Feb 27, 2025 3:31 PM UTC
You can query jobs triggered by a particular automation via rest api, this gives you the event id.
iamprem
  • Feb 27, 2025 4:37 PM UTC
Thank you for your response, ​@ebygomm . I'll give that a shot. However, I came across an article (https://support.safe.com/hc/en-us/articles/25407532206989-Monitoring-FME-Server-Job-Activity-using-the-REST-API) which mentions, 'Currently, the REST API does not support retrieving job history for each individual automation.'
It would be great if you could share any examples if you have them handy.
That would be very helpful.
Thanks.
  • Feb 28, 2025 10:09 AM UTC
iamprem
  • Feb 28, 2025 11:23 AM UTC
Thanks for sharing an example, this really helps. ​@ebygomm
iamprem
  • Mar 12, 2025 10:54 AM UTC
Hi ​@ebygomm ,
I want to extract a few published parameters for a workbench into a attribute, I used a similar xquery to do it, but it was not successful.
XQuery I used:
for $m in json:members(fme:get-json-attribute('publishedParameters'))
where $m('name') = "substationName" or $m('name') = "subnetworkName"
return fme:set-attribute($m('name'), $m('raw'))
How do I do this in a correct way? Suggestions?
Thanks.
  • Mar 12, 2025 11:22 AM UTC
Have you extracted the parameters, my workspace does something like this
then this in the xquery
for $m in jn:members(fme:get-json-attribute('parameters'))
iamprem
  • Mar 14, 2025 12:18 PM UTC
Thanks ​@ebygomm !
As part of this thread, I just want to ask another question related to this:
Is there a way to get all the logs for workbenches in a automation as a attribute?
