How to transfer a single automation to another server ?
  • May 21, 2024
  • 171 views
lifalin2016
Forum|alt.badge.img+40
Y’all.
I thought it was possible to export a single automation, and install it on another server ?
But now I can’t seem to find this feature anywhere (on 2022.6).
They’re backed up in the general configuration backup, but you can’t restore parts like a single automations from a backup.
Am I missing something ? What to do ?
Cheers.
Best answer by TandraAtSafe
Hi @lifalin2016, it sounds like you might want to use a project export to package up the automation and necessary workspaces.
You can read more about them in this article
If this doesn’t solve your problem please let me know and we can work through this further!
TandraAtSafe
Forum|alt.badge.img+8
  • May 21, 2024
lifalin2016
  • May 24, 2024
Thanks Tandra.
I didn’t know what to make of the “projects” option, but this examplifies it perfectly.
I even tried to import my 2022 project into a 2024 Flow, and although it was more intricate than importing to 2022, it worked out very nicely. Haven’t run it though, but everything seems to be in place.
Cheers.
