Assume I have an automation that starts with a directory watch to capture an updated zip file in a folder. The zip file name is passed as a parameter (File Path) to the 1st workspace. This workspace is followed by a second workspace, which needs to use the same zip file as a parameter. I can not figure out an easy way to feed the File Path (zip file path) to the second workspace as a parameter, other than writing it to a text file and let the 2nd workspace to read from the file. Any advice to make this easier and streamline? The FME server is 2020.1.3.
How to pass parameters to a chain of workspaces in automation?
Best answer by redgeographics
You should be able to set that in the parameters section of the Automation. Check out Chapter 4 of the FME Server Authoring training.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
