How to get input Revit filename for dynamic output in FeatureWriter?
  • Aug 29, 2024 1:14 PM UTC
  • 65 views
kelin84
I'm using a FeatureReader to import Revit (*.RVT) files. I need to loop through a folder of Revit files and write the output to a GDB using the same filename as the input Revit file.
I'm looking for something like fme.basename, but I can't find it anywhere, neither in the FeatureReader's geometric outputs nor in the schema. I can't find any attribute to expose that would give me the input filename. I've also tried FilenamePartExtractor, but I have nothing to put in the "Source Filename" field.
What am I missing here?
Thanks
tomfriedl
Forum|alt.badge.img+14
  • Aug 29, 2024 1:30 PM UTC
At the end of the dialog “FeatureReader > params” you can find “Schema Attributes” to expose fme_basename and / or fme_dataset.
