I have setup a FME Server Webhook trigger in the automations section and want to put the payload received into a database table by running a workspace after the action is triggered. Please help or advise if this is not the correct way? Thank you #Automation #Webhook
How to get FME Server Webhook Payload to Workspace in FME Desktop?
Best answer by ctredinnick
There is an article here which may help: https://community.safe.com/s/article/webhooks-and-fme-server
Working backwards, you want your workspace to write the payload to a database, so your workspace needs to get the payload. So you need a text parameter, to pass the payload into your workspace.
Then, in the FME Server automation, you can set the workspace parameter to receive the value of the webhook message content
To test run on desktop, you'll need to get the actual webhook payload. If you don't know what it looks like, you can add a logger to the automation, then trigger the webhook to see what is received by FME Server.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
