How to force a “flush” / reset state between multiple input files in the same FME workflow?
  • Dec 15, 2025 8:47 PM UTC
  • 127 views
francisco_1988
Forum|alt.badge.img+5
Hello everyone,
I’m working on an FME workspace where I need to process multiple input files sequentially within the same workflow, and I want to make sure that each file is processed independently, without any data or state being kept in memory from the previous file.
Conceptually, what I’m looking for is a way to flush or reset the internal state between files, so that:
  • cached features,
  • temporary aggregates,
  • statistics,
  • or in-memory objects
from a previously processed file do not affect the processing of the next one.
Context
  • I’m looping over multiple files (using a file-based workflow, not separate workspaces).
  • The workflow includes transformers that may keep internal state (e.g. aggregations, statistics, grouping, geometry operations).
  • The goal is to guarantee deterministic, per-file processing, similar to a “clean run” for each file.
My questions
  1. Is there a native way in FME to explicitly flush / reset the internal state of a workspace between input files?
  2. Are there specific transformers or workspace settings that:
    • automatically reset state per file, or
    • should be avoided when processing multiple files in the same run?
  3. Is the recommended approach to:
    • use a workspace per file,
    • use feature-based partitioning (e.g. Group By),
    • or rely on specific transformers (e.g. FeatureHolder, FeatureMerger, etc.) to isolate state?
Forum|alt.badge.img+54
  • Dec 16, 2025 9:27 AM UTC
If this is on FME Form, and all files are processed entirely independently of each other, then the cleanest way is to create a parent workspace with a workspace runner to run the child workspace once per file.
hkingsbury
Forum|alt.badge.img+73
  • Dec 17, 2025 7:49 PM UTC
In addition to using workspaces runners as suggested by ​@ebygomm you could also leverage groupby and fanouts on your writers
