Hi everybody! How can I fix the HTTP run time error? We have Publication that monitors and email Inbox. A service request on Cityworks is created when an email is received with a GIFF attachment. SR created should have the GIFF attachment but it randomly fails to attach the GIFF for some SRs. And gives HTTP time out error. I have checked the API calls and they look good in Postman. I checked with my network team as well, no issue on that side either. The log file indicates that it is 401 error- but Authentication is also intact as other SRs gets created successfully with GIFF attached. Please see the image below for errors. Any insights is highly appreciated. Thank you!
