How to dynamically feed different parameter values to a workspace in the server Automation?
  • Dec 3, 2020 5:52 PM UTC
  • 111 views
aguan
Forum|alt.badge.img+11
I have a workspace that takes one published parameter to run through. I want to set up a FME server weekly automation, and each weekly run includes running the workspace multiple times, each with a different parameter value. The parameter values are stored in a text file. Seems to be simple? But I can't think of a good way to do this. Still new to the FME server automation. I am using FME 2019.2.1, both desktop and server.
Best answer by david_r
our test server is 2020.1, but I don't see how to do this either in it. Any clue?
If the parameter values are always in the same text file, why not simply let a "master" workspace read the thext file and e.g. use the FMEServerJobSubmitter to launch the "child" workspace once for each of the parameter values.
  • Dec 3, 2020 5:53 PM UTC
Is upgrading to 2020.x an option? Automations did get a serious improvement compared to 2019.
aguan
  • Dec 3, 2020 6:58 PM UTC
  • Dec 4, 2020 10:24 AM UTC
aguan
  • Dec 6, 2020 10:10 PM UTC
@david_r. This works exactly like what I wanted. Thanks you very much.
