I'm trying to figure out how to use the directory watch on various user folders. The idea is when they update datasets it kicks off a job updating automatically.
How do you setup Directory Watch for folders on your local shared server.
Best answer by hollyatsafe
Hi @brianapeters,
If you are looking to watch a folder that isn’t in the FME Server System Share you will need to use the UNC path to set that directory in the Publication. If you are receiving an error then it is likely that the account running the FME Server Services does not have read/write permissions to view this file path.
See Step 5 here: http://docs.safe.com/fme/html/FME_Server_Documentation/Content/ReferenceManual/Directory_Watch_Publisher.htm for reference.
If the error still persists after you have corrected those permissions then please let me know what error is being reported.
