Hi I have a workspace that runs from Workbench but if i try to run from a Scheduled task i get no output I have put snips of the ERROR and FATAL messages below. This has happened in 2020.1.1.0 (20200801 - Build 20608 - WIN64) and 2020.1.0.0 Th
  • August 17, 2020
  • 14 replies
  • 119 views
adrian_farrell
17/08/2020 12:09  10.9  0.8  ERROR   Python Exception <ModuleNotFoundError>: No module named 'fmepy_emailer'
17/08/2020 12:09  10.9  0  FATAL   PythonFactory failed to load python symbol `fmepy_emailer.Emailer'
17/08/2020 12:09  10.9  0  FATAL   Factory proxy not initialized
17/08/2020 12:09  10.9  0  FATAL   Emailer_CALLER (PythonFactory): PythonFactory failed to process feature
17/08/2020 12:09  10.9  0  ERROR   Emailer_CALLER (PythonFactory): A fatal error has occurred. Check the logfile above for details
17/08/2020 12:09  10.9  0  ERROR   A fatal error has occurred. Check the logfile above for details
17/08/2020 12:09  10.9  0  ERROR   StringReplacer (StringReplacerFactory):
17/08/2020 12:09  10.9  0  FATAL   HTMLReportGenerator (PythonFactory): PythonFactory failed to close properly
17/08/2020 12:09  10.9  0  ERROR   HTMLReportGenerator (PythonFactory): A fatal error has occurred. Check the logfile above for details
This is running on Windows Server 2012 R2 Standard
Best answer by david_r
Hi
Thank you for the reply
We are using a standard Windows Scheduled task to Run a Batch file. The content of which is reproduced below
Net Stop "FME License Server"
Net Start "FME License Server"
"C:\\apps\\FME20608w64\\fme.exe" C:\\_FME\\_NewServer\\BC_UncommencedInspectedPlots.fmw
This runs as a separate account which has full administrator privileges to the machine, we have around 20 of these set up in exactly the same way (using different versions of FME but that is another story)
Sounds like packages referenced by the workspace that haven't been installed for that user. Yes, you can try to simply copy them over.
Forum|alt.badge.img+62
Are you using a different user account when running it as a scheduled task? If so, doublecheck whether that has the same PATH variable set as your account.
  • August 17, 2020
Can you show us how the scheduled task has been configured? If you're using a batch file, can you post the contents?
adrian_farrell
  • August 17, 2020
Thank you for replying
Yes the scheduled tasks run as a different Domain User
The Path variables are only set at system level so don't vary
There are several versions of FME installed so I have ensured that 2020.1.1.0 path comes first in the Path variable also
adrian_farrell
  • August 17, 2020
Hi
  • August 17, 2020
Hi
Have you tried logging into the machine as the admin user executing the scheduled task and run the workspace manually? Does that work?
adrian_farrell
  • August 17, 2020
Hi
Hi
I hadn't but have just done that and still same error. I executed it from Command Line logged in as the scheduled task user.
I also executed it from Command Line, logged in as me and that went through fine
  • August 17, 2020
Hi
"C:\apps\FME20608w64\fme.exe" C:\_FME\_NewServer\BC_UncommencedInspectedPlots.fmw
Sounds like it's an issue with the user profile, somehow.
While logged in as the scheduled task user, go to the command line and the FME home directory, then type the following commands, one by one:
fme python
import sys
sys.path
Check that the directories listed by sys.path are the same as for your personal user.
adrian_farrell
  • August 17, 2020
Hi
Hi
Four differences
Not present as scheduled user: C:\\Users\\{my user}\\AppData\\Roaming\\Safe Software\\FME\\Packages\\20608-win64\\python\\safe.emailer
Not present as scheduled user:  C:\\Users\\{my user}\\Documents\\FME\\Plugins\\Python\\python37
Different between my user and scheduled user:  "C:\\Users\\{scheduled user}\\Documents\\FME\\Plugins\\Python" & " C:\\Users\\{my user}\\Documents\\FME\\Plugins\\Python"
I have checked and the folders relating to 2020 installs of FME do not exist in "C:\\Users\\{scheduled user}\\AppData\\Roaming\\Safe Software\\FME\\Packages" - Is this just a case of copying them over?
Thanks
  • August 17, 2020
Hi
adrian_farrell
  • August 17, 2020
Hi
Thank you for your help with this
Copying the content of "C:\\Users\\{my user}\\AppData\\Roaming\\Safe Software\\FME\\Packages" to "C:\\Users\\{scheduled user}\\AppData\\Roaming\\Safe Software\\FME\\Packages" worked brilliantly, i brought across the other versions from that folder at the same time to ensure that these work should they ever be used in this way
Adrian
chau
Forum|alt.badge.img+3
  • November 6, 2020
Hi
Hi @david_r​
Why don't FME automatically fetch and install packages when encountering a package not installed for the current user?
  • November 6, 2020
Hi
That is an excellent question, but I cannot answer as I'm not involved in the development of FME. Consider posting it as a new question (to get better visibility) or contact Safe support directly.
ben_vanderford
I was having great difficulty with the emailer transformer and the package in FME server. I finally had to manually copy the package, safe.emailer, into the resources folders. Depending on where your resource folder is located I copied the safe.emailer folder into resources\\engine\\Packages\\20632-win32\\PackagesFiles and the resources\\engine\\Package\\20632-win32\\python folders. Restarted FME server and it started to work.
runneals
Forum|alt.badge.img+29
  • July 16, 2021
Having this issue with the newest version of the ArcGIS Online Connector from Hub and FME Server. How do I do this with FME Server?
