Help configuring FME Form to run RCaller
  • Jul 8, 2024 4:52 PM UTC
  • 0 replies
  • 122 views
willydevera
Forum|alt.badge.img+10
Hi!
I need help in configuring FME Form to run RCaller.
FME is not local in my machine; instead, I'm remoting in to a server to run Form from there. It's prompting me this error message:
    RCaller (InlineQueryFactory): Failed with exit code 1 when executing R script. Output was: Error in library("sqldf") : there is no package called 'sqldf'
    Execution halted
    Failed to execute scripted code.
I followed the steps indicated in https://docs.safe.com/fme/2017.0/html/FME_Desktop_Documentation/FME_Transformers/Transformers/rcaller.htm.
I configured the default paths and R Plugin files in: "C:\Program Files\R\R-4.4.1\bin\Plugins" and the Plugins folder contains the following files:
    assertthat
    BH
    bit
    bit64
    blob
    chron
    DBI
    digest
    gsubfn
    magrittr
    memoise
    pkgconfig
    plogr
    prettyunits
    proto
    RCpp
    RSQLite
    sqldf
I am not sure what's causing the error. Any help or piece of advice greatly appreciated.
Thanks,
Wilfredo
