Getting a list of items, workspaces, automations etc from fme flow
  • Mar 21, 2025 12:13 AM UTC
  • 9 replies
  • 571 views
jackyd
Forum|alt.badge.img+16
Hi everyone,
We are planning an fme upgrade shortly and I want to compile a list of the workspaces, automations and other items we have on our FME Flow instance to help plan for testing, and determining the amount of effort etc we will need to plan for.
Is there a way of doing this?
Does anyone have a process they can share?
Have had a look at using the api interface and http callers and could set something up with this, but hoping someone might have already done this that I could adapt for my systems. Or that there is a simpler native way that i have missed.
TIA
Jacky
Forum|alt.badge.img+63
I've been thinking of creating like a “FME Flow Quickscan” process, to do stuff like that: listing workspaces, connections etc. I haven't gotten around to doing it, but maybe I can whip something up in the next couple of weeks.
donalmateer
Forum|alt.badge.img+13
Hi ​@jackyd,
I don't think there's anything off hand - but some ways that you could go about it would be:
From the FME Flow Web UI:
  • Go to Repositories to view workspaces.
  • Go to Automations to view and export automations (.fmear).
If you want a full inventory, use FME Flow REST API:
FME Form with the HTTPCaller
A Python script with requests
  • List repositories: GET /fmerest/v3/repositories
  • List workspaces: GET /fmerest/v3/repositories/{repo}/items
  • List automations: GET /fmerest/v3/automations (edited)
Thank you!
alexbiz
Forum|alt.badge.img+35
  • Mar 25, 2025 4:43 PM UTC
You can export a backup, change the extension from fsbackup to zip and extract it.
This will give you all the items as well as metadata to process that way.
Toying around with it for a little bit, got a list of workspaces and users, is there anything else you'd want to see ​@jackyd ?
jackyd
  • May 28, 2025 1:36 AM UTC
Thanks Everyone,
Will take a dive into the some of this
Need to a similar things with our Arcgis for Portal
jackyd
  • May 28, 2025 1:40 AM UTC
Thanks Hans (@redgeographics)
Still working out what I need, but thinking I want automations and connections as well.
Trying to end up with a catalog of what we have and a reproducible process to help us keep track, particularly as we move towards a more self service model with our organisation. Trying to be in front of the curve and keep things to minor instead of major chaos
jackyd
  • May 29, 2025 5:26 AM UTC
Hi Everyone,
I have a draft workbench that extracts lots of info from FLOW
Going add some reporting outputs to make it human readable and fit some process docs we have.
But it is on its way.
mgg_beca
Forum|alt.badge.img+20
  • Oct 15, 2025 1:17 AM UTC
Hi Everyone,
This is useful thanks. ​@fme it would be great to have a documenter workspace included in the list of samples that spits out all info about flow that can be gleaned via the api - all schedules, automations, workspaces, dependencies etc.
jackyd
  • Oct 16, 2025 2:59 AM UTC
Hi Everyone,
Thanks ​@mgg_beca
Yes, started looking at that, but was there quite a bit involved and I got deep into the weeds of doing the upgrade, hopefully I can get back to it at some stage, but happy for you to have a go and take this one further if you are interested.
