FMEServer jobs not running after restart and small change to config
  • Jan 29, 2020 11:26 AM UTC
  • 10 replies
  • 83 views
paalped
Forum|alt.badge.img+11
Im experiencing jobs with tag "satskred" stuck in Queue after a small modification to the fmeServerConfig.txt
these are my changes:
# Job Routing
TM_QUEUE_TYPE=DEFAULT
TM_ENGINE_1=Engine1:fast default
TM_ENGINE_2=Engine2:fast satskred
# System Notifications
I've set the job tag as "satskred" on my Subscription Notification.
Before (job runs on 2 engines):
# Job Routing
I need the job to run on 1 single engine.
Engines:
Subscriptinon Advanced:
Job status:
Restarting:
Making new changes:
# Job Routing
# Legger inn denne endringen for å kjøre satskred på én engine (Enigne2)
TM_DEFAULT_TAG=default
TM_ENGINE_2=Engine2:fast satskred default
Every job without satskred tag runs...
Help appreciated!
Paal
sigtill
Forum|alt.badge.img+25
  • Jan 29, 2020 11:35 AM UTC
Hi @paalped Which version of FME Server do you use? I would suggest not to use the fmeconfig but rather create the queue from the FME Server GUI
paalped
  • Jan 29, 2020 12:06 PM UTC
Hei Sigbjørn, The Customer is using FME Server 2016.
sigtill
  • Jan 29, 2020 12:11 PM UTC
Did you restart the FME Server so it could properly load the fmeconfig and pick up the changes? @paalped
sigtill
  • Jan 29, 2020 12:15 PM UTC
Have you tried:
# Job Routing
TM_ENGINE_1=Engine1:default
TM_ENGINE_2=Engine2:satskred
paalped
Yes I have restared FME Server Core (service) mutliple times. I believe there is something wrong with my tag name setup.
sigtill
  • Jan 29, 2020 12:21 PM UTC
Is the engine actually called Engine1 and not COMPUTERNAME_Engine1 or LOCALHOST_Engine1 ?
paalped
  • Jan 29, 2020 12:27 PM UTC
Ah, where can I find the engine name?
sigtill
  • Jan 29, 2020 12:28 PM UTC
Seems to be wrong name of engine?
# Job Routing
TM_ENGINE_1=FMESERV02_Engine1:default
TM_ENGINE_2=FMESERV02_Engine2:satskred default
paalped
  • Jan 29, 2020 12:30 PM UTC
Thanks! I just followed the example, but sure the Engine name was different than the example :) Thank you!
sigtill
  • Jan 29, 2020 2:12 PM UTC
So now it works as expected @paalped ?
