FME Server Single Sign-On refuses logins while Active Directory login works fine
  • Nov 13, 2017 3:47 PM UTC
  • 30 replies
  • 1016 views
helmoet
Forum|alt.badge.img+8
Hi, It must be stunningly simple however we miss the clue, but we're trying to get FME Server to accept Single Sign-On logins. We connected to Active Directory, that seems to work nice since we can use a user and password from the domain and log in, that's a success.
Mon-13-Nov-2017 04:20:33.924 PM  INFORM  RequestHandler-Thread  401831 : Accepted new client connection from /127.0.0.1 on port 7,071
Mon-13-Nov-2017 04:20:33.926 PM  INFORM  RequestHandler-Thread  401933 : Successful login by user XX99999
However, when we press the Use Windows Credentials the login is denied and fmeserver.log shows this error message:
Mon-13-Nov-2017 04:23:22.734 PM  INFORM  RequestHandler-Thread  401831 : Accepted new client connection from /127.0.0.1 on port 7,071
Mon-13-Nov-2017 04:23:22.770 PM  INFORM  RequestHandler-Thread  408043 : (Single Sign-On)  Enabled single sign-on authentication.
Mon-13-Nov-2017 04:23:22.770 PM  INFORM  RequestHandler-Thread  408049 : (Single Sign-On)  Using pre-authenticated credentials (for a service account) to create server credentials...
Mon-13-Nov-2017 04:23:22.802 PM  INFORM  RequestHandler-Thread  408050 : (Single Sign-On)  Created server credentials.
Mon-13-Nov-2017 04:23:22.803 PM  INFORM  RequestHandler-Thread  408056 : (Single Sign-On)  Encountered negotiation requiring multiple steps; authentication still in progress...
Mon-13-Nov-2017 04:23:22.803 PM  ERROR  RequestHandler-Thread  Single sign-on authentication in progress
Mon-13-Nov-2017 04:23:22.807 PM  WARN  RequestHandler-Thread  401934 : Failed login by user YH0GBisGAQUFAqBzMHGgMDAuBgorBgEE... due to insufficient credentials.
Anybody any suggestions? What stuck me is that the user name seems to be encrypted, while if using the explicit credentials they are not.
Best answer by justincornell
Greetings @helmoet @RylanAtSafe.  We figured it out!!  I worked with @RichardAtSafe via a support ticket and it turned out the SPN's were to blame.  So the moral of the story is while the SIGNGLE_SIGN_ON_URL can be the CNAME in tomcat properties file and the url in the browser to FME Server can be a CNAME, there MUST be a SPN registration for the HOST name of the computer.  Below are the commands we ran to get it to work with the CNAME as the url.  The CNAME entries are needed to allow the server to be accessed via the friendly name in the browser and the host names are needed to allow SSO for FME Server.  The bold commands below were what fixed the issue.
CNAME SPN registrations
setspn -S http/testfme svcMyServiceAccount
setspn -S http/testfme.mydomain.com svcMyServiceAccount
HOST (machine name) SPN registrations
setspn -S http/MyMachineName svcMyServiceAccount
setspn -S http/MyMachineName.mydomain.com svcMyServiceAccount
Essentially what I think is happening is that when a Kerberos ticket is attempted to be generated it's using the machine name (HOST) despite the URL that is being specified in the SINGLE_SING_ON_URL.  It's likely a server side process generating the Keberos ticket which would mean the machine name needs to be registered with a SPN.
Hope this helps someone else figure this out.
rylanatsafe
Forum|alt.badge.img+14
Hi @helmoet - I'm sorry to hear about this!
Have you verified that the SSO Username and Password is using a Service Account with privileges to the Active Directory listings?
One "gotcha" is entering DOMAIN\\USERNAME for the 'Domain Search User' and the 'SSO Username' – the latter should be only USERNAME.
And are you trying to login using Windows Credentials on the same machine that FME Server is installed to? Please try from a different machine.
There are a couple non-FME Server configurations that may apply, so please make sure that all steps are satisfied as noted in documentation.
helmoet
  • Nov 13, 2017 6:49 PM UTC
Hi @Rylan, thanx for the suggestions. Not at the premises right now, so I'll have to check thursday. I'll notice the workforce, they can look into this in the meantime.
Yet I think the service account we're using has rights to the Active Directory listings, since that part seems to work fine. However, a good suggestion is to use another account (for testing)
I'm pretty sure the DOMAIN\\USERNAME gotch did not catch us (we tried both possibilities and kept the good one).
We tried from another machine, that indeed didn't work, we still have to do something on the Tomcat configuration. If we use 'localhost' in the URL, we see the Use Windows Credentials button, however, if we use the fully qualified server name in the URL, we get a different login screen without the button.
However, I checked the External facing URL setting in the Tomcat Properties file, yet no success so far. But for sure, there is some work to do on that file, too.
rylanatsafe
@helmoet - I cannot reproduce this behaviour and I would expect the "Use Windows Credentials" button to appear for both URLs. Please submit a ticket to Safe Support with the FME Server log files so we can investigate further. It would also be great to test multiple browsers as well to see if there is any change in behaviour (IE, Chrome, Firefox).
  • Nov 14, 2017 3:38 PM UTC
On behalf of Helmoet the generated log files during single sign on are attached (.zip)
fme-logging.zip
Hi, I think the username is case sensitive, and this could also cause problems.
rylanatsafe
fme-logging.zip
Thank you for sharing the log files, @gu19495. Unfortunately I could not identify anything – save for the SSO errors in fmeserver.log – that may be the root cause. Please contact Safe Support to open a support ticket so we can deep dive into the investigation.
  • Nov 16, 2017 10:58 AM UTC
After change DEBUG_LEVEL to FINEST (tomcat propertiesFile.properties) interesting logging showed up:
INFORM RequestHandler-Thread 408053 : (Single Sign-On) Negotiation reported an error: "Failure unspecified at GSS-API level (Mechanism level: Encryption type AES256 CTS mode with HMAC SHA1-96 is not supported/enabled)".
WARN RequestHandler-Thread 408058 : (Single Sign-On) Failed authentication because of an negotiation error. Refer to single sign-on documentation for resolution.
ERROR RequestHandler-Thread Single sign-on authentication failed
WARN RequestHandler-Thread 401934 : Failed login by user YIIQWAYGKwYBBQUCoIIQTDCCEEigMDAu... due to insufficient credentials.
We are investigating whether TLS cipher suite EAS265 should be added...
rylanatsafe
@gu19495 - Great detective work! The error you have highlighted matches the symptom reported in this Knowledge Center article. Let us know if the suggested resolution works for you!
helmoet
  • Nov 17, 2017 12:41 PM UTC
Yep, @RylanAtSafe we found that one, too, We will probably choose the alternative to use a certificate and implement SSL. That will do the trick I suspect, so no support tickets needed. Thankx a lot for all the support. And thanks @gu19495 Andre for the hard work. I will keep this issue informed on the outcome.
helmoet
  • Nov 17, 2017 12:42 PM UTC
True, definitely true.
  • Nov 17, 2017 1:25 PM UTC
@helmoet, @RylanAtSafe thank you for thinking along !!
I installed the Java Cryptography Extension (JCE)
https://knowledge.safe.com/articles/395/enabling-aes256-in-the-java-runtime-environment-fo.html
This did not solve the issue but fmeserver.log now shows this:
INFORM RequestHandler-Thread 408053 : (Single Sign-On) Negotiation reported an error: "Failure unspecified at GSS-API level (Mechanism level: Checksum failed)".
WARN RequestHandler-Thread 401934 : Failed login by user YIIQWQYGKwYBBQUCoIIQTTCCEEmgMDAu... due to insufficient credentials.
Windows Domain Configuration is updated with these ServicePrincipalNames:
http/t-fmeserver.gasunie.nl <service account>
http/t-fmeserver <sercice account>
Web Browser configuration is configured as follows:
'Local intranet'. => http://t-fmeserver and http://t-fmeserver.gasunie.nl
'Advanced' tab => Enable Integrated Windows Authentication is checked.
rylanatsafe
Hi @gu19495 , some of my colleagues are actively investigating this issue with our dev team. At least one other instance of this error has cropped up and they are checking for common symptoms. As far as your configuration is concerned, it does appear to be correct as you have it posted.
  • Jan 22, 2018 8:49 PM UTC
Hi @RylanAtSafe
I can login with my Windows Credentials as long as I type them in, but if I click on "Use Windows Credentials", I get a message saying "You are not authorized to access this web application".
Then I checked the FMEServer.log.
408041 : (Login Module) Authenticating single sign-on token "YIIJBwYGKwYBBQUCoIII+zCCCPegMDAu...".
401934 : Failed login by user YIIJBwYGKwYBBQUCoIII+zCCCPegMDAu... due to insufficient credentials.
My user ID is all lower case both in AD and in the FME Users.
Since all the FME users have been imported from AD, and they can login with their Windows Credentials, I don't think there is anything wrong with the AD settings. I followed the instruction in https://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/IWA.htm for these AD settings.
rylanatsafe
Hi @RylanAtSafe
Hi @fardosht, I'm really sorry to hear that this has affected yet another user! If you haven't already done so, please contact Safe Support referencing this Q&A; Thread and include an fmeserver.log file that shows the occurrence of this error. This will ensure that we can formally track the issue.
Note: I have reached out to you from a previous support ticket that might have been opened in relation.
UPDATE: This was resolved by correcting the SPNs registered to the Service Account. Please see documentation for more details. The FME Server Troubleshooting Article has been updated.
rylanatsafe
Hi @gu19495 - If you are still experiencing issues related to SSO, please contact Safe Support referencing this Q&A; Thread.
helmoet
  • Jan 23, 2018 1:20 PM UTC
Hi @gu19495, @RylanAtSafe,
We still experience SSL trouble, logging in using typed-in user/password is successful (as long as we type UPPERCASE username), however the SingleSignon button does not work (stating "Login failed, please try again").
What reminds me on the fact that we use IE for accessing the FME Server UI. I opened the console messages during the log in to FME Server, with the resulting image below. What strikes me is the last message, which states that CORS is needed for this action. I don’t know if this is some kind of error message, yet I take it to be some kind of license check.
“SEC7118: XMLHttpRequest for https://fmestartup.safe.com/server/?product=server&platform;=win64&build;_string=FME%20Server%202017.1.1%20-%20Build%2017650%20-%20win64&build;=17650 required Cross Origin Resource Sharing (CORS).”
Would it be possible that this has something to do with our FME Server / SSL issue?
Regards, Helmoet.
rylanatsafe
Regards, Helmoet.
Hi @helmoet - I tested explicitly blocking this URL and it did not appear to affect the login process. Great idea to check the Developer Tools!
I'm not certain but my understanding is fmestartup.safe.com is linked to our Marketing Department – if you navigate to that URL, it displays the latest banner (observed in FME Workbench).
(Tested: FME Server 2018.0 Build 18251 Win64, SSO Enabled)
bjarne
Forum|alt.badge.img+5
  • Apr 7, 2018 8:52 PM UTC
Hi, I had a similar experience.
I followed the https steps "To use a CA-issued certificate", but I had to import the certificate into ...\\Utilities\\jre\\lib\\security\\cacerts as well before Single Sign-On logins worked.
revesz
Forum|alt.badge.img+22
  • Oct 1, 2018 4:28 PM UTC
Thanks a lot, the 'SSO Username' should be only USERNAME hint made the whole thing work :)
@RylanAtSafe is it necessary to have SSL enabled to use SSO? I'm using FME Server 2018.1.1.1 - Build 18578 - win64
@helmoet and @RylanAtSafe did you ever find a resolution for this issue?  I've double checked the SPN settings, case sensitivity of the "Service Account Name"  (without domain specified) and added the crypto libraries as suggested in a commend above.  Nevertheless I am still experiencing problems connecting with SSO with the error log below.  We're using  FME Server 2018.1.1.1 - Build 18578 - win64
INFORM   pool-3-thread-1   408078 : (Active Directory) Connecting using directory configuration "mydomain.com"...
INFORM   pool-3-thread-1   408001 : (Active Directory) Connecting to an available server in ( DCSERVER.mydomain.com:389 )...
INFORM   pool-3-thread-1   408002 : (Active Directory) Successfully connected to DCSERVER.mydomain.com.
INFORM   pool-3-thread-1   408065 : (Active Directory) Connected server is an Active Directory server.
INFORM   pool-3-thread-1   408066 : (Active Directory) Default user name attribute is "sAMAccountName".
INFORM   pool-3-thread-1   408067 : (Active Directory) Default user full name attribute is "displayName".
INFORM   pool-3-thread-1   408073 : (Active Directory) Default user mail attribute is "mail".
INFORM   pool-3-thread-1   408068 : (Active Directory) Default group name attribute is "sAMAccountName".
INFORM   pool-3-thread-1   408004 : (Active Directory) Found default search base "DC=mydomain,DC=com".
INFORM   pool-3-thread-1   408037 : (Active Directory) Using connected server "DCSERVER.mydomain.com" as KDC.
INFORM   pool-3-thread-1   408038 : (Active Directory) Using domain name of connected server "mydomain.com" as realm.
INFORM   pool-3-thread-1   408029 : (Active Directory) Found supported SASL mechanism "GSSAPI".
INFORM   pool-3-thread-1   408029 : (Active Directory) Found supported SASL mechanism "GSS-SPNEGO".
INFORM   pool-3-thread-1   408029 : (Active Directory) Found supported SASL mechanism "EXTERNAL".
INFORM   pool-3-thread-1   408029 : (Active Directory) Found supported SASL mechanism "DIGEST-MD5".
INFORM   pool-3-thread-1   408040 : (Active Directory) Configured to use simple authentication.
INFORM   pool-3-thread-1   408007 : (Active Directory) Authenticating user "mydomain\svcMyServiceAccount"...
INFORM   pool-3-thread-1   408060 : (Active Directory) Successfully connected to DCSERVER.mydomain.com.
INFORM   pool-3-thread-1   408079 : (Active Directory) Successfully connected using directory configuration "mydomain.com" and encountered 0 errors.
INFORM   Health Check Thread for LDAPConnectionPool(serverSet=RoundRobinServerSet(servers={DCSERVER.mydomain.com:389}), maxConnections=100)   408060 : (Active Directory) Successfully connected to DCSERVER.mydomain.com.
INFORM   RequestHandler-Thread   401831 : Accepted new client connection from /127.0.0.1 on port 7071
WARN     RequestHandler-Thread   401934 : Failed login by user YIIQbwYGKwYBBQUCoIIQYzCCEF+gMDAu... due to insufficient credentials.
What is this user specified in the log file?  How can we make sense of that value? YIIQbwYGKwYBBQUCoIIQYzCCEF+gMDAu...
rylanatsafe
@justincornell - No, it is not necessary.
rylanatsafe
Hi @justincornell – I'm sorry to hear another user has encountered this! I don't think there had been any changes to the product as a result of the issue presented in this Q&A thread. It likely did not escalate after being resolved by (at least one of) the two solutions suggested here.
However, as you note that they have not worked – please contact Safe Support for further assistance. If you reference this Q&A URL, it will be helpful.
The user denoted "YIIQbwYGKwYBBQUCoIIQYzCCEF+gMDAu.." refers to an internal token that the product defaults to in this scenario. You will notice this error for different users. I don't have any developers on hand I can ask right now (Christmas holidays!) but it is an encrypted value nonetheless. It shows up only in relation to specific login issues – usually related to AD configurations.
@RylanAtSafe thanks for the response. I've submitted a case with support. When I get a resolution I'll make sure I post it here for others. Even if it's a silly mistake on my part :)
helmoet
  • Dec 31, 2018 10:38 AM UTC
Hi @justincornell @RylanAtSafe @gu19495 sorry, this item did not get full priority for us. We still did not resolve this issue. What struck me recently is that we could use both FME Server credentials AND Active Directory logins (i.e., typed in, not through the "Use Windows Credentials" button) to log in FME Server (we're using FME Server 2017.1).
