FME server directory watch - can publication exclude some file extensions?
  • Nov 12, 2018 5:23 PM UTC
  • 82 views
aguan
Forum|alt.badge.img+11
I set up a directory watch in FME server to watch changed shape files in a directory. Since each shape file has 7 components, updating one shape file will trigger 7 notifications, causing the subscribing workspace to run 7 times. I would hope the directory watch publication has an option to watch only ".shp" files so that each shape file change only triggers one notification. Any work around about this?
Best answer by david_r
This is a known limitation, I'm not aware of any easy way to circumvent this short of asking the users to zip their files before placing them in the watched folder.
There are at least two ideas for improvements, please consider voting:
https://knowledge.safe.com/content/idea/81501/add-file-type-filtering-on-directory-watch-in-fme.html
https://knowledge.safe.com/content/idea/39299/regexp-support-on-fme-server-directory-watcher.html
  • Nov 12, 2018 6:00 PM UTC
Hi @ag,
It is not currently possible to specify a single file type to watch, please consider upvoting this idea: https://knowledge.safe.com/content/idea/81501/add-file-type-filtering-on-directory-watch-in-fme.html.
To avoid your current predicament can I suggest reviewing Davids answer on this post: https://knowledge.safe.com/questions/21091/directory-watch-file-types.html to analyse the JSON message for the correct file type first.
aguan
  • Nov 12, 2018 7:15 PM UTC
@david_r and @hollyatsafe, I voted for both. For most cases file extension should be sufficient, but a wild card could be very useful.
  • Nov 12, 2018 7:19 PM UTC
Thanks for giving your vote. I share your opinion.
