javax.crypto.IllegalBlockSizeException: Data must not be longer than 245 bytes
when trying to change and save Automation (schedule trigger + 3x sequenced workspaces)
FME Server win64, b19643
Got an error when trying to set on trigger Start Date&Time - error after Save button click.
Any suggestion?
Best answer by rylanatsafe
Hi @arekpierchala, I'm sorry that you have encountered this error. A similar posting was made by another FME Community member – they were able to identify that this error was related to a 'Password' Published Parameter in one of the Workspace actions.
I was able to get the Automation to save/run by manually overriding that password parameter within the Automation dialog
Hope that helps! If you still have issues, please use the 'Report a Problem' form on our FME Technical Support page.
just wanted to update you that a recent change in the latest release of FME 2020.0.1 should have fixed this error message if you'd like to give it a try. You can find it in the downloads page here.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
