FME server 2022 Some or all of the input parameters are invalid
vanessarapior
 Hello
I get this message on FME Server 2022 and I do not know what is wrong.
Forum|alt.badge.img+49
When do you get that message? When running a workspace? If so, have you checked the input parameters?
vanessarapior
  • August 19, 2024
I get this message when I want to create a Scedule on the server. Then this message pops up even when I filled all parameters and I do not see any (typing) error.
j.botterill
Forum|alt.badge.img+40
  • August 19, 2024
When publishing the workspace in Form, make sure you click on the Register (web) Services = Job Submitter.
vanessarapior
  • August 19, 2024
I can run it on the Servewr, but I cannot create the Scedule for it.
I have the Job Submitter
But maybe it is this:
Could it be that the Scedule does not like the number here and I have to create user parameter?
siennaatsafe
Forum|alt.badge.img+11
Hi @vanessarapior ,
Unfortunately, I can’t see the error message you are getting when trying to create a schedule. Maybe your attachments aren’t working.
Would you mind sharing the error message as text instead? This would give us a better idea of what’s going wrong.
vanessarapior
  • September 20, 2024
@siennaatsafe the error message is
“Some or all of the input parameters are invalid” when I want to create a scedule. Then I cannot do anything else instead of starting from the beginning.
siennaatsafe
Hi @vanessarapior
Can you send a screenshot of how you have the SpeedCatSource parameter configured in FME Form?
Can you send a Screenshot of how you have the parameters configured in both the Run Workspace page and the Schedule?
Thanks,
Sienna
