FME Flow - Workspace App not giving "User can Upload" option
  • Feb 13, 2024 9:39 PM UTC
  • 396 views
ponting13
Hi Team,
I am trying to create workspace applications in a newly installed instance of FME Flow 2023.1.1 (has to match our Form version) and when creating Workspace applications I can no longer select the "User can Upload" option on any newly created workspaces.
If I select workspaces a historic workspace (brought in via backup from 2022) the option is there.
The only thing in changed in between screenshots was selecting a different workspace (same user, repository and service)
Any ideas? All help appreciated
Best answer by merlinegeorge
Hello ,
Would you be able to create a support case with the following information -
Is this an intermittent issue ?
Try to create a duplicate of the Flow App  using Actions > Duplicate. Is the User Can Upload toggle correctly displayed for the duplicate app ?
Does the workspace use the Data Upload Service or  published parameter that represents a file used by the workspace ? Do you also see this issue for these workspaces too?
ponting13
  • Feb 13, 2024 10:23 PM UTC
I have found a solution, but I’m not sure it's the correct one:
  1. Just create the app without the "User can Upload" option
  2. Go into the token for the app
  3. add the “Data Upload” service.
This then allows users to upload files in the app.
However, the app still doesn't show the option for "User can Upload" when editing it
merlinegeorge
  • Feb 15, 2024 6:35 PM UTC
Hello ,
