FME Cloud receiving email when paused
  • October 2, 2017
  • 29 views
Forum|alt.badge.img+62
Looking for some confirmation here:
If I have set up a publication in FME Cloud to use the built-in SMTP email and send an email to it while it's paused it never gets delivered and thus the associated workspace never gets triggered, correct?
Best answer by stewartatsafe
That is correct yes. The email server is running on the same FME Cloud instance so when the instance is paused it isn't running. To make this work you'd have to use an external SMTP service such as Gmail and then connect to that inbox when the instance comes online.
stewartatsafe
Forum|alt.badge.img+9
  • October 2, 2017
rylanatsafe
Forum|alt.badge.img+14
  • October 2, 2017
My expectation would be... "No, never gets triggered." However, some mail servers do have retries for non-deliverables and will send a notification (i.e. bounce-back) to you each time. I would say it's within the realm of possibility that an email to FME Cloud may bounce-back when it's paused, but then on this 're-submit' could pass through when the FME Cloud instance is up.
Thanks for confirming that, will have to rethink an idea :) (or invest in a 24/7 FME Cloud)
