FME Automations - Merge - Invalid Link
  • Apr 10, 2025 2:51 PM UTC
  • 84 views
Forum|alt.badge.img+54
I’m trying to set up an automation with a merge process similar to what is described here
Getting Started with the Split-Merge Block – FME Support Center
However, when I try to add in a Merge action to the Failure port I get the following error message
Has anyone encountered this? I’m using the Merge Tool with a Failure Port so I’m not sure why it’s complaining
FME 2024.1 Build 24612
nia.colebrooke
Forum|alt.badge.img+4
Hi ebygomm,
This error is because you are using both the split merge block and the merge action downstream of an automation parameter port.
To fix this and to get the split merge block to correctly merge messages coming out of the automation parameter port, drag the workspace using the automation parameter into the split merge block with your passfailterminate workspace. Redo the connections once the workspace has been moved.
