FME Automation Triggering an FTP Directory and providing a CAD/Rivet file uploaded as a parameter for a workspace issue.
  • Nov 3, 2022 11:14 AM UTC
  • 36 views
FTP File PathI'm having an issue regarding the FME Automation triggering the automation when a new file is added to an FTP Directory and running a workspace that needs a parameter of a CAD File or Rivet File, but the Cad/Rivet Reader is showing an error which fails the workspace, I am using the file path in the FTP directory to read it as a parameter. Rivet ErrorAutoCAD Error
f.kemminje
Forum|alt.badge.img+11
  • Nov 3, 2022 11:52 AM UTC
The directory name or folder name is also included while inputting the AutoCAD filename, as I can see in the image. Trim the text string containing the supplied file names to remove any folder names.
