FME API Automation topic trigger and external action query
  • January 15, 2025
  • 5 replies
  • 118 views
vn1
Forum|alt.badge.img+4
If an automation is triggered by a schedule, you can obtain the schedule properties via the Schedules list.  https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/schedules/list
If an automation is triggered by a topic, how do you obtain the name(s) of the topic(s) that trigger that automation?
If an automation posts to a topic, how do you obtain the name(s) of the topic(s) that automation posts to?
Best answer by hkingsbury
I’ve attached an example workspace that makes used of the /fmerest/v3/automations/workflows/@Value(id)/components api - which is undocumented.
It returns a json object that contains all the components in an automation. You can then break this down and find what topics are called.
hkingsbury
Forum|alt.badge.img+67
  • January 15, 2025
vn1
  • January 16, 2025
Thank you.  This appears to achieve the result.  Is there any known reason why the components api is undocumented?
hkingsbury
  • January 17, 2025
Great question, at a guess it’s because it’s viewed more as an internal API and not something Safe is expecting people to interact with. There are quite a few instances like this.
@rylanatsafe are you able to give some insight into why some APIs are documented and some aren’t?
rylanatsafe
Forum|alt.badge.img+14
  • January 18, 2025
@hkingsbury that’s a great question!
We focus on documenting API endpoints with strong external use cases. Endpoints primarily used by internal processes, like the Flow UI, are less likely to be documented to allow for more flexibility in making improvements or breaking changes.
Some undocumented endpoints might not be optimized for general use and encouraging their widespread use (through API documentation) could impact application performance, though that is generally an uncommon case.
The /components part of the Automations API remains undocumented in the V4 Flow REST API. I recognize the need for better insights into object connectivity and dependencies in FME Flow. The scenario described aligns with feedback we’ve seen, and we’re exploring options to address in the future.
Thank you for the tag! Your suggestion is a clever approach to obtaining the topic information.
whichwayisnorth
Forum|alt.badge.img+3
Just adding to say that I’d wished I’d found this earlier! I’ve just finished a workbench which can assign tags to automations related to data endpoint, schedule frequency, automation status, and categories.
I ended up having to pull the node information from the automations directly from the PostgreSQL database to achieve it as information pertaining to my tags was scattered across emailers, triggers, workspaces, and more. It still worked though and I managed to automatically assign tags to over 250 automations. The best part being converting cron expressions into frequency labels such as daily, weekly, etc.
I am glad that I found this though, because my next task was mass updating emailer details and I needed to identify which emailers contained certain key words and I was trying to figure out the best way to modify them - wasn’t hugely keen on trying to modifying the database records.
