FME API Automation topic trigger and external action query
  • Jan 15, 2025 7:26 PM UTC
  • 11 replies
  • 312 views
vn1
Forum|alt.badge.img+4
If an automation is triggered by a schedule, you can obtain the schedule properties via the Schedules list.  https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/schedules/list
If an automation is triggered by a topic, how do you obtain the name(s) of the topic(s) that trigger that automation?
If an automation posts to a topic, how do you obtain the name(s) of the topic(s) that automation posts to?
Best answer by hkingsbury
I’ve attached an example workspace that makes used of the /fmerest/v3/automations/workflows/@Value(id)/components api - which is undocumented.
It returns a json object that contains all the components in an automation. You can then break this down and find what topics are called.
hkingsbury
Forum|alt.badge.img+73
  • Jan 15, 2025 8:58 PM UTC
vn1
  • Jan 16, 2025 12:07 PM UTC
Thank you.  This appears to achieve the result.  Is there any known reason why the components api is undocumented?
hkingsbury
  • Jan 17, 2025 12:51 AM UTC
Great question, at a guess it’s because it’s viewed more as an internal API and not something Safe is expecting people to interact with. There are quite a few instances like this.
​@rylanatsafe are you able to give some insight into why some APIs are documented and some aren’t?
rylanatsafe
Forum|alt.badge.img+14
​@hkingsbury that’s a great question!
We focus on documenting API endpoints with strong external use cases. Endpoints primarily used by internal processes, like the Flow UI, are less likely to be documented to allow for more flexibility in making improvements or breaking changes.
Some undocumented endpoints might not be optimized for general use and encouraging their widespread use (through API documentation) could impact application performance, though that is generally an uncommon case.
The /components part of the Automations API remains undocumented in the V4 Flow REST API. I recognize the need for better insights into object connectivity and dependencies in FME Flow. The scenario described aligns with feedback we’ve seen, and we’re exploring options to address in the future.
Thank you for the tag! Your suggestion is a clever approach to obtaining the topic information.
whichwayisnorth
Forum|alt.badge.img+5
Just adding to say that I’d wished I’d found this earlier! I’ve just finished a workbench which can assign tags to automations related to data endpoint, schedule frequency, automation status, and categories.
I ended up having to pull the node information from the automations directly from the PostgreSQL database to achieve it as information pertaining to my tags was scattered across emailers, triggers, workspaces, and more. It still worked though and I managed to automatically assign tags to over 250 automations. The best part being converting cron expressions into frequency labels such as daily, weekly, etc.
I am glad that I found this though, because my next task was mass updating emailer details and I needed to identify which emailers contained certain key words and I was trying to figure out the best way to modify them - wasn’t hugely keen on trying to modifying the database records.
madhusudan
  • Apr 16, 2026 1:03 PM UTC
Is there any way to get the component using rest api v4?
whichwayisnorth
​@madhusudan
Hey, it’s not much different from v3.
{fme_flow_domain}/fmeapiv4/automations/{id}/components
I’ve just tested it successfully.
madhusudan
  • Jun 2, 2026 5:31 PM UTC
​@whichwayisnorth Thank you so much for the quick response. I have quick question from this can we extract the scheduler information in automation like cran timing and all. I am not sure as I am not seeing through my fme flow domain or I do not have access to certain automation or scheduler. Once again thank you so much.
Forum|alt.badge.img+54
  • Jun 2, 2026 6:49 PM UTC
The following api call will give you the information about any automations that have a schedule trigger, including cron statement etc.
FMEURL/fmeapiv4/schedules?limit=100&offset=0&sourceType=automation
madhusudan
  • Jun 3, 2026 11:23 AM UTC
​@ebygomm Perfect, it’s working. Thank you so much!
madhusudan
  • Jun 24, 2026 11:16 PM UTC
​@rylanatsafe ​@ebygomm ​@hkingsbury ​@vn1 ​@whichwayisnorth ​@david_r  ​@j.botterillThank you all for your help. I really appreciate it. I have quick questions.
  1. I run this FMEURL/fmeapiv4/schedules?limit=100&offset=0&sourceType=automation, when I add source type to this URL I am getting an error. Maybe because all the schedules set in “schedules”?
  2. When I run this URL {fme_flow_domain}/fmeapiv4/automations/{id}/components, when I see the cron expression the time set for automation I extract through API is different and in UI the time show me is different. For instance, one automation in UI shows daily 3:20 PM but it used to run on 12:30AM and in cron expression through API shows me 00:30:00. Is there any bug in FME or something is wrong over here.
  3. What's interesting, is that we didn't' set the schedule via Cron, but we set it via basic scheduler, and then FME converts that into a CRON to be read. Basically, we set as basic scheduler, but when we extract through API, it shows us as basic Cron type.
  4. The problem we have is we cannot identify the schedule for flows until something runs (if set via basic scheduler) due to the visual glitch. So, we haven't been able to keep tabs on the times Flows will run. Therefore, we would need to either change every single schedule to a CRON expression??
  5. And I would like to see what other information we can extract out of this, such as connections, deployment parameters, owners and text like
  • Author Information
  • Name(s):
  • Departments(s):
  • Unit(s): Customer Information
  • Name(s):
  • Department(s):
  • Unit(s):
Once again thank you so much for your support and consideration. It means a lot to us.
