Flow jobs failing on python script using exportToPDF
  • Jan 29, 2025 12:21 AM UTC
  • 12 replies
  • 522 views
joshmon
Forum|alt.badge.img+3
I have several automated jobs that use either a startup or shutdown python script.  These scripts run fine in workbench and even in the ESRI Python interpreter on the Flow machine.  The issue arises when I run them from Flow.  When it gets to the script it will output expected products until the exportToPDF command at which point it fails.  No errors are indicated anywhere except in the Engine Log where this is displayed: WARN     localhost_Engine2   393562 : Process "localhost_Engine2" ended unexpectedly. Being restarted on attempt 1…
Example of script:
import arcpy, os, sys, time, shutil
from datetime import datetime
sdpFolder = r"****OBSCURED****"
exportFolder = os.path.join(sdpFolder, "SiteDevPlanFiles")
date = time.strftime("%Y-%m-%d")
dateFolder = os.path.join(exportFolder, date)
archiveFolder = os.path.join(sdpFolder, "_Archive")
zipExportFolder = exportFolder + ".zip"
# from zipfile import ZipFile
# for file in ZipFile(zipExportFolder).namelist():
# archive previous zip
destZip = os.path.join(sdpFolder, "SiteDevPlanFiles.zip")
for x in os.scandir(exportFolder):
print(x.path)
if x.is_dir() and x.path != dateFolder:
#move old date folder to archive folder
archivedDateFolder = os.path.join(archiveFolder,date)
if not os.path.exists(archivedDateFolder):
shutil.move(x.path,archiveFolder)
#delete old copy of SiteDevPlanFiles.zip
try:
except:
print("fail")
if os.path.exists(destZip):
os.remove(destZip)
if not os.path.exists(dateFolder):
os.mkdir(dateFolder)
aprx = arcpy.mp.ArcGISProject(r"****OBSCURED****".aprx")
layouts = aprx.listLayouts("*")
for l in layouts:
#loop through all layouts in folder
print("-" * 50 + "\nLayout: " + l.name)
output = os.path.join(dateFolder, date+"_"+l.name)
print(output)
# export layouts with map series for phasing to pdf
if not l.mapSeries is None:
ms = l.mapSeries
if ms.enabled:
ms.refresh()
#print(f"--- {ms.pageCount} pages")
ms.refresh()
print("Test Break 1")
ms.exportToPDF(output,embed_fonts=True,
georef_info=False)
# export layouts for sitewide phasing to pdf
elif l.mapSeries is None and "Phasing" in l.name:
# exportName = os.path.join(dateFolder, date+"_"+l.name)
l.exportToPDF(output,
embed_fonts=True,
georef_info=False)
shutil.make_archive(exportFolder, 'zip', exportFolder)
dalneberg
Forum|alt.badge.img+5
  • Mar 7, 2025 10:03 AM UTC
I have exact same problem.
It works fine in FME Form but not in FME Flow. It also works fine on my machine (with Windows 11) in Windows scheduler where I have a runner.bat that runs a pythonfile with the pythoncode below.
But it does not work on a Windows Server (We have upgraded from Windows Server 2019 to 2022 but it did not make any difference).
I have tried with ArcGIS Server on the server, and with only ArcGISPro (3.3) on the server (with MicrosoftEdgeWebView2RuntimeInstallerX64 installed).
I also tried with a older version of ArcGISPro.
I have all admin permissions on the folders and in task scheduler.
So, the question is what can cause this arcpy.exportToPDF to fail? and without any errormessages.
import arcpy, os
def main():
    print(f"1")
    # Ange sökvägar
    prjPath = os.path.normpath(r'C:\temp\fme')
    outputPath = os.path.normpath(r'C:\temp\fme\testoutput')
    print(f"2")
    path = os.path.join(prjPath, 'Test_PDFutskrift.aprx')
    print(f"2.1")
    # Öppna ArcGIS Pro-projektet
    p = arcpy.mp.ArcGISProject(path)
    print(f"3")
    # Lista av layoutnamn
    layoutNames = ['A3', 'A2']
    for name in layoutNames:
        # Hämta layout
        print(f"4")
        layouts = p.listLayouts(name)
        if len(layouts) == 0:
            print(f"Layout {name} finns inte i projektet.")
            continue
        lyt = layouts[0]
        # Sökväg för PDF-export
        pdfPath = os.path.join(outputPath, f"{name}.pdf")
        print(f"Försöker exportera {name} till {pdfPath}...")
        # Exportera till PDF
        try:
            lyt.exportToPDF(pdfPath)
            print(f"Lyckades exportera {name} till {pdfPath}.")
        except Exception as e:
            print(f"Misslyckades med att exportera {name} till PDF: {e}")
if __name__ == "__main__":
    main()
dylan.at.safe
Forum|alt.badge.img+9
Hi ​@dalneberg and ​@joshmon,
Can you provide the versions of FME Form/Flow and ArcGIS Server you’re using? Here are a few things to check:
Please let me know if there is any other relevant information about the environment that would help us reproduce this issue.
—Dylan
dalneberg
  • Mar 12, 2025 7:59 AM UTC
Hi ​@dylan.at.safe
FME Form 2024.2.1, FME Flow 2024.2.1
ArcGIS Server 11.3.
See also below that i tested with ArcGISPro 2.9, 3.3 and 3.4 on the machine.
This is from the fmeprocessmonitorengine.log:
localhost_Engine1   Started translation command: 'Systemgruppen_scripts\Test_export_arcpy\Test_export_arcpy.fmw'
localhost_Engine1   INFORM: An ArcGIS license is already checked out. The product checked out is 'ArcServer'
localhost_Engine1
localhost_Engine1   Reading...
localhost_Engine1   Emptying factory pipeline
localhost_Engine1   Translation was SUCCESSFUL with 0 warning(s) (0 feature(s) output)
I have tested allmost every versions of Python, it makes no difference.
Yes, fme flow service account have permission to write to the destinationfolder.
I have done some tests do run the python-script from the Task Scheduler and this is the result:
It works on my machine (with Windows 11) in Windows scheduler (with option: Run whether user is logged in or not). (I have a runner.bat that runs a pythonfile.)
On this Windows server it only works to run when i run it right in the commandtool, or in a windows task scheduler with the option: Run only when the user is logged on.
I have tried with ArcGIS Enterprise 11.3 on the server, and also tried with only ArcGISPro (2.9, 3.3 and 3.4) on the server. All with MicrosoftEdgeWebView2RuntimeInstallerX64 installed (test is done with version 133.0.3065.92 and 134.0.3124.51).
The thing is that it worked well until dec 2024/jan 2025, we upgraded both FME Flow and ArcGIS in that period.
dalneberg
  • Mar 13, 2025 6:53 AM UTC
Hi ​@dylan.at.safe
FME Form 2024.2.1 and FME Flow 2024.2.1
I get the following message in the fmeprocessmonitorengine.log:
localhost_Engine1
Yes, and I have tested almost every version of python.
Yes, the FME Flow service account have permission to write to the destination folder.
I have done tests do run the script in the Task scheduler and this is the results:
I have tried with ArcGIS Server on the server, and also tried with only ArcGISPro (2.9, 3.3 and 3.4) on the server. Both with MicrosoftEdgeWebView2RuntimeInstallerX64 installed (test is done with version 133.0.3065.92 and 134.0.3124.51).
i.o
Participant
  • Participant
  • Apr 2, 2025 9:29 AM UTC
We are also experiencing the same issue, both with "exportToPDF" and when attempting "exportToPNG." It seems as though FLOW completely stops during the process—there are no error messages. Even a built-in logging mechanism within the script only generates outputs up to the "exportToPDF" call. No error exceptions are being reported.
Is there a solution or workaround available?
dylan.at.safe
Hi ​@i.o,
Apologies, I meant to update this thread earlier. We're still investigating the root cause of the issue. Given the number of variables that could be involved, I recommend opening a support case with us, especially if this is impacting your production environment.
As soon as we have a fix, or workaround is available, I will post more details in this thread.
–Dylan
dbecker
  • Apr 10, 2025 1:02 PM UTC
So, our “local” FME support from conterra gave us the crucial hint (again) which was already in this thread: It seems that this is the culprit and exportToPDF() or exportToPNG() only work with an active display session.
We tried to run this example as a scheduled task on our server and it only works with the “run only when the user is logged on” option. Giving the FME-Server service user the interavtive login rights does not help either.
import arcpy
aprx = arcpy.mp.ArcGISProject(r"Printlayout.aprx")
lyt = aprx.listLayouts("Seite1")[0]
lyt.exportToPDF(r"printlayout.pdf", resolution=300)
I guess someone has to open a case with esri. :|
joshmon
  • Apr 10, 2025 8:41 PM UTC
Verified the above behavior in our environment.  Script would only run from Task Scheduler with “run only when the user is logged on” option, not “run whether user is logged on or not”.
Also, checked the AD accounts used by Flow and all use a specific ‘Log on as” account while FME Flow Database uses ‘Local System’.  I tried to change to the AD account the other services use but it refused to start back up so I changed it back.
Our versions are : Windows Server 2022, ArcGIS Pro 3.3 and FME Flow 2024.1.2
dylan.at.safe
This issue seems to be tied closely with Licensing FME Flow with ArcGIS Pro. While technically possible to use ArcGIS Pro with FME Flow, we don’t currently support it. I’ve tested this in FME Form 2024.2.1, FME Flow 2024.2.1 with ArcGIS Server 11.3 and Windows Server 2022 and was unable to reproduce the issue.
Additionally, it’s possible in environments with Python previously installed or environments with multiple versions of Python, the wrong path will be used. Importing sys and using print("\n".join(sys.path)) can help troubleshoot this issue.
dalneberg
  • May 28, 2025 9:05 AM UTC
​@joshmon ​@dbecker ​@dylan.at.safe
Hi, this problem is now solved in our enviroment! i.e. exporting pdf with arcpy via task scheduler and then also via FME Flow, works again!
It started working on 20/5 after our IT installed the month's windows patches on the entire production environment, they also updated vmware tools in connection with that. Now it is vmware version 12.5.2. The guy at IT is unsure what version it was before.
I have not received any confirmation what made this particular thing start working again, it would have been interesting to know.
dbecker
  • May 28, 2025 9:38 AM UTC
Interesting, thanks for the heads up. Maybe this bug in VMWare Tools is the reason in this case as well: Error: ArcGIS Server Print Service and Caching Controller Crash When VMWare 12.5 is Instal
We actually encountered this problem in our Esri Enterprise environments as well.
I will check with our server admins. :)
timatsafe
Forum|alt.badge.img+8
  • Apr 15, 2026 9:00 PM UTC
Just wanted to sharing what I found helping ​@joshmon with this issue. It seems like this may by due to an problem with one of the Python modules in the ArcGIS Server environment.
Reinstalling the lxml module with using the following pip command in Command Prompt seems to have helped:
"C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\python.exe" -m pip install lxml --force-reinstall
