Find CAD coordinates in FME and use CAD to build a 3D model
  • Apr 18, 2024 5:09 AM UTC
  • 5 replies
  • 255 views
changge
Can anyone help me, I am going to build an indoor 3D model in FME through CAD floor plan, when I import the CAD drawing into FME and execute the stretch command, open the inspector I find the coordinates, and find that the values related to the coordinates are all 0, and the coordinate system is also the location, in addition, after finally converting the CAD file to CityGml format, I opened it with Notepad and found that it was all null values, how to solve it
Best answer by evieatsafe
Hi @changge if possible could you provide your workspace? Just want to make sure that your writer is set up correctly. As well, you may want to set your coordinate system before writing with a CoordinateSystemSetter or Reprojector transformer. Here are some additional resources on writing to CityGML:
changge
  • Apr 18, 2024 5:11 AM UTC
Sorry for the mistake, the coordinate system is unknown
evieatsafe
Forum|alt.badge.img+28
  • Apr 19, 2024 9:33 PM UTC
changge
  • Apr 21, 2024 6:25 AM UTC
Thank you
changge
  • Apr 21, 2024 6:56 AM UTC
Thanks for the reply, I imported a CAD floor plan with windows
After the scaler and extruder operations, some window faces are obtained
After following the method you provided
I write it out, and when I got a CityGml file, I opened it with Notepad and found that there was no data
How can I get a file that can be opened and viewed by FKZViewer software, forgive me for being stupid and look forward to your reply.
evieatsafe
  • May 28, 2024 5:04 PM UTC
Sorry for the late reply. @changge Are you able to provide your workspace or a screenshot of your writer parameters? From your latest reply it looks like your attributes are not exposed and are not being written out to your writer either, but hard to say without your workspace. Sorry for not being able to help further at the moment.
