Emailer Attachment
  • October 23, 2019
  • 5 replies
  • 307 views
pflegpet
Forum|alt.badge.img+8
I'm trying to set up a workflow where I attach the intermediate result of a workspace to an Email as an Excel spreadsheet but I have troubles writing only one file. The Emailer documentation hints at using TempPathNameCreator and a FeatureWriter but I could not find any concrete examples on FME hub. When I run the translation every feature is written to a separate Excel file instead of a single one. I'm sure this can easily be done but I can't figure out how. Thanks for any help!
Best answer by itay
Hi @kasparlov,
How is the FeatureWriter configured? can you share a screendump of the settings?
itay
Forum|alt.badge.img+18
  • October 23, 2019
Hi @kasparlov,
pflegpet
  • October 23, 2019
Hi @kasparlov,
Hi, the current setup looks like this:
virtualcitymatt
Forum|alt.badge.img+47
Hi @kasparlov,
Ahh, yeah, for each feature passing through the TempPathnameCreator you will get a new path. Instead of directing all your features though it you can use a separate branch with a Creator to create the temp path. Make sure the FeatureMerger is set to Suppliers First so that it doesn't cause a memory block.
itay
  • October 23, 2019
Yes @virtualcitymatt is correct a single feature for a single path is needed.
pflegpet
  • October 23, 2019
Thank you @virtualcitymatt, it works now as expected.
